2015 2500 tow mirror
Jeff156.7
2015 2500 6.7l
6.7 cummins
Need help I am about to buy a ram 2500 cummins.. The truck does not come with tow mirrors. I'm being told it can't be done.. The mirrors on the truck are manual fold heated no blinker.
I really want to switch out right away I'm not buying that it can't be done. Has anyone had this issue or could be of any help?? It's an slt
Darwin
The Mountains of N.E. California
They can be ordered on a new Ram 2500 and they cost $189.00 as an option. But if you order them from Mopar they are $1,100.00 to add to your rig later. They told me that they couldn't be added too and I found that to not be true at all. You may want to order one with the mirrors installed as that would be the cheapest and by far the easiest solution.
J
Jeff156.7
2015 2500 6.7l
6.7 cummins
Which mirrors did yours come with? Mine don't have blinker. I'm assuming you made the switch my truck is an slt. Since the blinkers aren't on the regular mirrors will the blinkers work with the tows?
Darwin
I have the SLT with no blinkers and I refused to spend the $1,000.00 on something that could have cost $189.00. So I went aftermarket cheapies. You can have your rig re-flashed they say to get the mirrors to work with your rig. Be careful though because the temperature gauge is in the drivers mirror in the 14 and newer. If you get the wrong ones it won't even run right they say. Good luck.
Loaded
Upstate NY
5.7L
Right. You will need to have sales codes LEB and LEC flashed and the code for tow mirrors as well.
wreckertc
