2015 5.7 hemi 2500? Anything to watch for?
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Looking at trading my Tacoma in and getting a 2015 5.7L hemi 2500. Has 40k miles and owner says he has full maintenance records and that it’s been well taken care of.
Anything I should watch out for? Or if this year/motor is not known for being very solid, please let me know because there are newer ones I’m also considering but I can pick this one for around $29k
Reason for wanting for a gas 2500:
1. when towing 6-10k lbs, I don’t want to feel like I’m being pushed around by the trailer like I have before when towing with a half ton (Chevy 5.3 and Ford ecoboost)
2. Don’t want to pay for a diesel lol
Toddz
San Bernardino
The 5.7 has been around for a long time. There are some who have issues with lifters, but gm has the same issues. Just make sure it is quiet (ie no hemi tick) and if you want to use it for towing, I would pay attention to gear ratio. If it doesn't have a 4.10, I would budget for a gear swap in the future. It should serve you well at those weights and will be so much more relaxing towing.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Thanks for the info! I checked the online build sheet and it has the 3.73 gears. What are you guys seeing for front and rear a gear change cost?
chris1126
RAMINA
pa
i would have to check reciepts, but i think i had $3500-4000 in mine having a shop do it. let me get back to you for sure. :hmm:
Toddz
San Bernardino
I had front and rear done for $2100 out here in California, so It depends on the area.
Toddz
San Bernardino
3.73s are a good middle of the road gearing for towing and you might be content with it. I am just the type where I try and find the best compromise for towing and driving. That has caused me to regear my last 3 trucks.
huntergreen
Marine Corps Navy Badge
The 5.7 will get your towing job done, but I would be looking for a 6.4 hemi in a 2500.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
That’s the other motor I’m looking at. Is there a noticeable difference between the two? And how is resale between the two?
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Bump... looking at the truck today. Anything I should specifically look for?
Thelegendl23
I have a 15 ram 2500.. expect to do lifters and rollers if you buy a hemi, if you don't end up doing it great!
I have the 6.4 and 5.7 both are solid and close to the same motor mechanically speaking.
All trucks have issues.
huntergreen
Only HD trucks I have had had the 5.9 Cummins. The 6.4 has a little more power. Might want ask this in HD section. When I buy used vehicles, I always let a machanic go over it.
