2015 6.4 H 5500 wont turn over HELP
Twduck1972
Vallejo ca
Cummings 6.7
Alright guys, I have a 2015 5500 with a 6.4 Heimi.
I Went out in the morning to start it and leave it clicked once but did not turn over. I checked the battery the battery is at 12.6 amps I checked the fuzes, the coil wires they too are at 12.6 amps. I went and replaced the starter thinking maybe the starter was bad when I put the new starter in same thing one nice loud click from the starter and nothing else. what are your suggestions?
pacofortacos
Check your battery voltage when it clicks or turn your headlights on and see if they really dim or go out when it clicks. Might just be a bad battery.
If that checks out ok, might want to try to turn the engine by hand (key off) and make sure it isn't locked up or hydrauliced.
mvm2
