2015 8 speed transmission temp...
ram5.7hemi
N/A
N/A
Anyone know what the temp ranges are for the 8 speed transmission? I know the 8 speed is designed to run hotter...
I tow a travel trailer a lot and ran into head winds the rams mission was at 208 degrees. I know the light will come on if it gets too hot but would like to know what too hot is so I can monitor it?
R.L.K.
Bristol , Tn.
There was a discussion on this a while back , you have nothing to worry about Sir .
Don't quote me but I think the normal range for the 8 speed xsmn is 180° -190 not towing.
The 8 speed does run hotter , it heats up via a thermostat that utilizes the coolant temp to heat it up quickly to 180 .
I'll post the discussion if I can find it .
Hope this helps !
Mishalnr
our normal 8 speed temps in saudi arabia are 87-93c
