hankRam2015
- Joined
- Aug 17, 2015
- Posts
- 996
- Reaction score
- 307
- Ram Year
- 2015
- Engine
- Hemi
Help. I am doing mine as we speak, the lower until under the center stack, the cig lighter had a clip easy, but the USB on the left looks straight wired and there is no play to unsnap it, do you recall how you undid it?
I cut wire. There were two I used one that was plug and play with one on console bezel. First I cut a spare power cord I had laying around and splice one end to end to wire and the other end to usb plug. Make sure you leave enough wire on both ends when you remove, so you can police. The plug and must be unplugged from back of usb. Then cut leaving 1" of spare wire. Then splice wire (power cord in my case ) to extend 12". Then plug into the bezel console. The other cords for usb/aux inside console armrest come from under seat. Hopefully that helps...
Remember there are only two wires. As long as you match colors you will have no issue
