2015 Ram 1500 Express, Crew Cab 5.7 Hemi
Black1500Ram
Scottsdale, AZ
2015 Ram 1500 Express Crew Cab – 5.7 HEMI V8 – 8spd -159k – Clean Running Truck
This is a solid, reliable truck that’s been properly maintained and mechanically sorted—not a perfect show truck, but a strong daily/work truck.
✅ Major HEMI issue already handled
Cam & lifters replaced at 117k (OEM parts)
Hellcat oil pump (oem sping no excessive PSI), Mopar performance valve springs, timing chain, water pump all done
✅ Suspension refreshed
Bilstein 5100s (+2” front), (1.5") coil spacers rear, new front upper & lower control arms, tie rods, Freedom Offroad Rear Control Arms, Helwig rear sway bar, end links, all bushings replaced, rear differential refreshed (Koyo bearings)
Drives tight, no slop
✅ Upgrades
AFE shorty headers w/ 10.9 bolts, Ramflex gaskets (no HEMI tick)
Carven exhaust with J pipe 1/4 resonator (sounds great, no drone)
Falken Wildpeak AT3 tires
Kansei flow formed wheels (21lbs)
Tri Fold Bed Cover
Grille Shutter Delete
Caulk Trans heater bypass
✅ Maintenance
Oil changes & tires rotated every 5k
5w30 Valvoline HM Extended Protection (high molly)
Fluids done (diffs, trans, t-case)
upgraded speakers + backup cam
⚠️ Cons (being upfront):
Cosmetic wear (dings/scratches)
Paint damage on passenger rear door
Bottom line:
If you know these trucks, you know the cam/lifter job is the big one—and it’s already done.
This truck is ready to go.
Asking $13,900
LINK to my hemi lifter job thread
Message me with questions
MADDOG
Living in a Firepit
6.4L HEMI
You need to update this ad with two items:
1. An asking price.
2. One more picture with an actual sign in the form of a sheet of paper with the date, your forum username and the forum name is required and should be shown next to the item in the picture.
You can review the For Sale Rules in post #2 here:
RamForum Site Rules
