2015 Ram MDS Delete
CORam15
Hello everyone, I feel I unfortunately reached the point with the 5.7 Hemi that I either have to replace the lifters (cylinder 1 misfire with a heavy tick) or sell the truck. I have done a little bit of research on MDS Delete kits by BTR and AMS racing. However, I honestly don't know enough about engines to know which to get. I am truthfully trying to buy one that someone else can help me install to save some change on the labor costs. Seeing as this is a common problem with these engines, I am hopeful this is the proper area to ask for assistance deciding what to get. Any help is appreciated. Thank you!
Just for reference:
-I already changed the plugs, coil pack, and fuel injector.
-The code does not populate until higher RPMs and there is a heavy popping in the exhaust at 1400 RPM in certain gears.
-I am not trying to tune the truck after the install has been dune, but if absolutely necessary I have someone that can help with it as well.
-I don't need any exponential increase in power. Nor do I need to chop of the "Truck Norris" setup.
BlackDodge1134
