2015 Ram Valve stems
Tyrant
'12CC / '15RCSB
Hey guys,
just wondering if you sell the valve stems for the 2015 Ram, they are a bit different from the other years so i cant use my spare valve stems from my 2012.
would appreciate if you could help me out, VIN is:
3C6JR6BT7FG546939
T
Tyrant
'12CC / '15RCSB
think is solved it.
part number: 68206635AB
pretty expensive for valve stems tho (15$ each)
chopperman1
2018 Rebel
5.7L HEMI
It's not just 5$ valve stem tho, it's a part of the TPMS, threaded brass fitting, screw etc. Is there a reason you need new ones? If for a 2nd set of rims I would think you would need the whole TPMS setup. If leaking are you sure it's the stem itself and not just the valve core which can be tightened or replaced?
T
Tyrant
'12CC / '15RCSB
no leaks or issues here, I'm replacing my wheels with the sport wheels and will swap over the sensors and tires from my current setup. Thats why I need new valve stems, the part number above is infact the full stem including the brass fitting and core.
The reason the price surprised me was that a few years ago I bought a full set of valve stems for the price above.
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
I see you have the correct part number listed above. It does include a new screw as well for attaching to the sensor.
-Benny
KAKA
