Well i did my research and couldn't find much at all related to this so i figured i would do a very brief write up for anyone in the future looking to do this swap as well. First and foremost, it IS possible!
I started out with a 2015 SLT ecodiesel.. ordered the sport hood, grill (complete), bumper and all of the bumper supports/nuts/bolts/etc (very important you order everything), as well as the black sport headlights. Everything bolts right up no problem at all.
For the hood its a very quick and simple direct change, the fake vent inserts aren't fun to install but it goes without saying, take your time. undo the 4 bolts holding the hood to the hinges and disconnect the sprayer line, i ordered new latch and liner so i simply bolted my complete new hood up after assembling it.
The grill is pretty self explanatory, i had to swap my shroud that clips on the back of it (not sure if the hemi has the shroud as well but the ecodiesel does) but its a simple 2 minute unclip & clip job. then just the 4 clips and bolts that hold the grill to the truck.
For the headlights they of course bolt right up as every headlight from 09+ does, but you will need to grab an adapter harness from the retro shop so you can plug them in (13+ dual load resistor harness). Get the plugs the right way or they wont work.
As for the bumper it as well is a pretty simple and straight forward swap. Nothing specific needed but you DO NEED to order every mounting part for the sport bumper (except the side deflectors...probably the wrong name for them) they bolt under each headlight and you can just leave them on. But be sure to order all of the u-nuts, bolt, plastic "rivets" etc as you WILL need them.
Hopefully that helps some people in the future, any questions just ask. Pictures for your time.
Good Job.
