2016 1500 Passenger Rear light out, turn signal works
Fs8888
Saskatchewan
Ecodiesel
I’m getting passenger rear light is out, but the hazards/turn signal work for the same bulb? Any others experienced that?
1999 White C5 Coupe
You'd probably get more answers if you posted this in the 4th Gen section.
Check your 3rd brake light,if it has a dud bulb it'll give you that message
The center, high-mounted brake light assembly has two brake light bulbs. If one stops working, often you will get the message in post #1.
Some believe the high-mounted brake light is working fully when they see the lamp illuminate, when one of the two bulbs are not functioning.
F
Fs8888
Saskatchewan
Ecodiesel
I reread my post and it wasn’t clear, my bad. That bulb does not illuminate when brakes on, but it does with the hazards/turn signal.
MB_RAM
California
V6
I had a similar problem after replacing my LED tail lights with aftermarket (2020 1500). "Left turn signal out." It was driving me crazy! It "dinged" and the dash lit up nearly every time I hit the brake. Everything worked perfectly, but the warning was going off and I'd get hyper blink inside for 2 months. Dealer told me there's nothing they could do. It was bc the system didn't like my aftermarket tail lights (voltage blah, blah, blah). I was desperate!
SOLVED... I was low on fuel. the "Low fuel" warning light kicked on. "Left turn signal out" light stopped. I was afraid to refuel, but of course I eventually did. The warning never went off again. I don't know why, but I'm telling you that's what happened. Give it a try!
