2016 laramie power wagon
02ram47
Bethel, Me
4.7 magnum
I just bought a 2016 Laramie Power Wagon. I want to lift it and do exhaust and tires. I am curious what lift everyone preferred. I know you have to buy the specific lift for the Power Wagon. i like the Rough Country 4.5" lift option. I don't want to spend huge money on BDS but I do love that lift. Has anyone installed the MBRP 4" dual cat back? I am just looking for some ideas all across the board.
Nick@GotExhaust
Preferred Vendor
SC
Hi, the MBRP is a popular option. Great sound, nice and deep! Fitment is very good as well. Let me know if you would like a quote, just send me a message.
For the lift kit, I can not recommend anything from RC but I do know options are limited for the power wagon.
bigdodge
Thuren is the way of you can afford it
62Blazer
Midwest
For the suspension almost everybody will jump on here and recommend Thuren or Carli. However you are limited to only about 1.5" - 2" lift with those components, which is equivalent to about 3" of lift on a regular Ram 2500. To be honest I've followed PW specific pages on the internet and Facebook for years and everybody trashes on the RC lift kits, but of all the people who trash on them I don't think any of them actually had the lifts or any real-world experience with them. It was all the "somebody else said that RC was junk so I'm just repeating what they said". Check out the IWRocker YouTube channel as I believe he had the RC kit on his and actually used it off-road. Maybe the RC kit is junk and will cause the truck to explode and kill a bus full of nuns....just have never seen any actual examples from people with the kit that there are issues..........
crazy jerry
WY
if your only picking up groceries just put steel pucks on top the springs. cheap and easy
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
35” tires will fit without a lift. 4.5” lift is pretty high if you really off road. That really moves your center of gravity. 2” lift with the right offset, will allow 37” tires to fit.
62Blazer
Midwest
Even though Facebook experts will throw a fit if you mention spring spacers on a PW, I'm sure there are a lot on the road with them. Several years ago there was a guy with a popular YouTube channel who ran a PW with spacers on the front and 37's for a few years and regularly pulled trailers (it wasn't a PW specific channel, but the truck was shown a lot) and he never mentioned any issues. To be honest I don't see how the typical 1.5"-2" front coil spacers would be any different on a PW versus any of the other thousands of Ram 2500's with spacers running around.
62Blazer
Midwest
A 4.5" lift on these trucks really isn't that tall nor will cause any major issues with the center of gravity. I've been into trailriding and rockcrawling for 20 years and ran a fullsize K5 Blazer that had a 4" lift and 40" tires that was considered a really low lift 10 years ago. Keep in mind that people were putting 12" lifts on fullsize trucks to handle that size tires and where this whole too much lift and high center gravity originates from. Used to be a guy showed up with a 12" and everybody talked about how it was too tall and would tip over and a 4" lift was really short. Now you have the inverse "big fish story" going on where people say a 4" lift is too tall.
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
Fo me, the shortest lift to accommodate the tire size I want. Not an inch taller. I clear the garage by 1/2 inch on my 35s.
olyelr
Kewadin MI
When i bought my ‘16 power wagon laramie new 7 years ago i quickly slapped a 1.5” leveling spacer on the front to get the truck leveled before i finally figured out which leveling springs i wanted to go with. Well, 72k miles later im still running the stock coils and shocks with the spacer lol. It has worked well for me with absolutely no issues. And i flog the truck every summer in the sand dunes and have had oodles of bottoming out fun. But crazy jerry is right, i have absolutely nonissues getting my groceries either.
The one thing i didnt do, though, was use the shock extenders that came with the kit. Because when i was taking calculations, it seemed that without bumpstop drops the shocks would end up bottoming out before the bumpstops did. Obviously not desirable.
olyelr
Kewadin MI
But the thing is, unless you are running 38’s or bigger and are scared to do a little trimming, anything over a few inches on a power wagon is not needed. Unless you are just looking for that super tall truck look (not knocking…to each their own). And, most 6” kits for a 3/4 ton ram (or 4.5” kits for a power wagon) come with transfer case indexing rings to clock the case because the output is too high for the factory driveline. No thanks.
olyelr
Kewadin MI
Here is a pic i took of my exact truck and it has a 4” power wagon bds lift with 37’s. Too tall imo. I would rather it be a a few inches shorter and have the tires tucked in under the flares more. But thats all personal preference.
BowerPower
Arkansas
When it comes to car modifications, the best advice I can give is "buy once, cry once".
I have no personal experience installing a rough country lifts but I am told the none of the shops in my town will install rough country lifts. I was a mechanic for 5 years and I have seen what happens long term with cheap lifts. Suspension components wear out at a constant rate and in come cases they can be aligned properly anymore. Most of that is on IFS trucks so take it with a grain of salt.
If your goal is to fit bigger tires, then you don't need 4.5" lift. AEV can fit 42" or 40" tires with a 3 inch lift over a stock 2500 and moving the front axle forward an inch. A power wagon can fit 37" with 0"-1" lift no problem. If your goal is to have a tall tuck for the looks and on the cheap then buy all means buy from rough country. If you care about ride quality and reliability then you should probably look into something else.
Me personally I will either fork over the cash to get a Carli system one day or never lift it. Il
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
Agreed!
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
Trailmaker
Locked and Loaded
Conroe Texas
2019 PW
Gray one is on AT 35s with no lift. And the red one is on MT 37s with a 1.5 wheel spacer. Light trimming
buckeyexx
Ohio
2016 Power Wagon
Maybe check out the proryde leveling kit if leveling is an option. Thinking of doing this setup myself If I end up leveling it.
62Blazer
Midwest
I won't argue with either of the above. Personally run 1.5" Thuren front coils on 37x13.50R17's and it took quite a bit of metal cutting on the inside of the fenders to reasonably clear, but can still rub lightly when off-road with the swaybar unhooked. I run 40's with a 4" lift on my off-road truck that could only fit 32" tires stock. That truck has major fender trimming to get those tires to fit, so I'm well versed on low lifts to fit big tires. Again, only saying that 4.5" of lift on a 2500 Ram isn't exactly huge compared to what people were doing not too long ago.
Vicman
Valdese, NC
2016 Power Wagon
Stock 16PW with 35's and I almost need a trampoline to get in. Can't imagine 4" more...Old guy with titanium knees. LOL:oops:
