2016 RAM 1500 fuel strap failed, no TSB or recall?
Hemimania
Central NJ
I had the strap replaced on my 2017 last year. No cost to me. I got the letter years ago, filed it away. Brought it to the dealer, no issues.
F$#@ YEEEEESSS. Just found the letter from 2018. LOVE YOU GUYS.
Tonino
Hemimania
Central NJ
U guys are the best here. This happened to me yesterday, just found the recall letter in my files, going to Ram later today.
This message board is a God sent.
Tonino
DILLIGAF
Canadian Forces
Canada
For the cost of 2 straps, and the couple minutes they take to change, why would you want to waste your time going to stealersh!t...lol...
Hemimania
Central NJ
Stealership called and they are covering the bracket. I'll ask today when they call but i forgot to ask, are they covering both straps or just the one that broke? Also, ironically enough, at the same time the bracket broke (with about 20 gallons of gas in it), bolts on the right side exhaust also broke that they are claiming the strap breaking didn't cause. I didn't look yet but considering everything else was fine until then. Any thoughts?
Thanks,
Tonino
RamDiver
Marlborough, Ontario Canada
2021 DS
Thanks,
Tonino
This sounds a bit like a sudden impact event could have caused these failures.
Did you get too much air jumping the railroad tracks and slammed the truck on landing? :cool:
Tommyva
Vestal
Hello, I have a 2016 RAM 1500 5.7 with 95k. Bought it brand new. Last week, noticed fuel strap rotted out of frame rail causing fuel tank to droop. Took it to a friend's shop and fastened with ratchet strap. Called dealer where I bought truck, they said my year and VIN are not part of the recall or TSB. Evidently there is a recall for earlier model years - Safety Recall U04 / NHTSA 18V-160 Frame Bracket. I shouldn't have to pay for the repair if it is a known issue. Any suggestions?
I have a 2017 1500 Laramie, I received a letter 6 years or so ago regarding the staps being replaced free of charge. If you have not done so, log into Uconnect, enter your VIN and see what they have listed. Dealerships make mistakes!!!
RamDiver
2021 DS
That's great info to share.
In future, if using a PC, mouse over the username, on phones, tap on the username to see the last online dates.
The OP has been MIA since 10/06 last year. :cool:
