J-13GTP
Hey guys I recently broke my tail light switch and had to have a calibration done. I had a local shop running a snap on diagnostics tool run the calibration. They started talking with ABS module and ran the calibration. Everything seemed fine until a few miles down the road I get a service electric braking system. I'm getting a P1C4E and P0572 code.
The P0572 code is for brake switch circuit low. I believe this code is setting off the P1C4E code. The P1C4E code is a general trouble code for the ABS module. However the tail lights are working correctly.
Everything on the truck was working fine before the replacement switch and calibration. Could I have a bad part or maybe something else needed to be calibrated. I believe its something in the software that needs to be changed or calibrated maybe not just the ABS module. Does any one have any insight. Its possible my mechanic missed a step in the process.
