2017 Ram 1500 2wd 5.7, New Rough Country Intake - MAF Sensor seems loose..
ericgray1
Diamondhead, MS
2017 Ram 1500 5.7 2wd
Installed a Rough Country Cold Air Intake.
The grommet that holds the Mass Air Flow Sensor seems loose. May not be keeping the sensor in the correct position to register the proper air flow reading. How can I make it sit tighter in place?
Put the stock box back on,it's as good a cold air intake as any of the aftermarket intakes,if not better then most.
If you want hunt up the eco-diesals lower box and install it.You got suckered.
If you're hung up on keeping a box that doesn't seal up the IAT sensor,either hunt up a grommet that's tighter,or try wrapping the sensor with several layers of black tape to increase it's diameter
BTW it's your Intake Air Temp sensor,the trucks don't have a maf sensor in the intake trac
ram150082
