chrisg_ky
Back in Dec I went out to start my truck cranked but would not start. So I thought my fuel pump was bad so I replaced it. Truck still did not start. So I replaced the tipm. Turns over buy sputters no start.
Replaced the cam, crank and map sensor still no start. Took to Dodge to have them work on it. Here is is the stuff they did in this picture. Drove home fine. Still didn't trust it so I started it the next and let run in my drive way. I forgot about and it was still running an hr or so later. To day I drive in town to buy dog food maybe 30mins drive. Park truck go in store and come out. Truck starts. Drive 5 minutes to Kroger and it dies just as I pull in the parking spot. Seems like it dies near idle. Only codes I have are due to the catalytic converter being removed before I bought the truck 420 and 430. Drove for a year fine like this. Dealer also said PCM voltage checked out. But I still feel like the PCM, rf module or ignition module, TPSM or the new fuel pump is faulty still. I also suspect the reluctor wheel or tone wheel but why would it run for an hr or long perfectly fine then die. I only have basic scan tool. That's why I ended up taking it To dodge. I've search several forums and all 20 of them have never responded to the fix except a bad fuel relay in the tipm which I have replaced. Is possible this could still be bad as well. At my wits end. Can't seem to find a good shop that can diagnose electrical issues.
