2018 3500 with Aisin, checking trans fluid level
RAS NJ
New Jersey
Cummins 6.7
I routinely check engine oil and NOT trans level. Bought truck w/ 32K miles and changed all fluids including trans and diff shortly after purchase. 45k miles now. I don't think I've ever checked trans fluid cold. 1st time this morning and fluid was well above hot mark just under twist in dipstick. Do I have too much trans fluid in?
thoughts greatly appriciated
yes I'm about to go drive and check hot
tjfdesmo
AZ
The "Cold" level is OK for rough estimate, but you really should check the final level "Hot", when at normal operating temp, and with engine running.
Runaround
Silsbee
Make sure you are checking in Park or Nuetral whichever is shown on the dipstick.
RAS NJ
RAS NJ
New Jersey
Cummins 6.7
When up to temp in park level was a hair above the hot level so overall thinks it's ok. Thanks for the input guys
