OtterlyFoolish
I have a 2018 RAM 2500 Laramie with 6.4 HEMI that has been driving me nuts for months now. Radio, CarPlay & Heated Seats usually stop functioning shortly after starting but sometimes 20 minutes into my drive. Everything functions on the next start about half the time. Had three places check the battery, charging and starting systems because I started seeing "Battery Saver Mode" on the dash. One told me that the starter was causing problems so I changes that out along with the battery temp sensor at the negative terminal thinking that it was sensing a draw that wasn't there. The truck always starts without any struggle and I can leave it for weeks at a time without problems so I do not think there is a parasitic draw. I kept the original starter and battery sensor as spares seeing how they were not the problem.
In the past I had the 8.4 Uconnect radio delaminate and I replaced it with one from Amazon. Ran that radio for a year before these issues started without any issues. I bought another 8.4 Uconnect thinking that it was the problem but the same problems exist after replacing it a second time so now I have a spare radio too.
I also replaced the ABS HCU about a year ago with whatever part number superseded the original.
Other issues I have experienced are my compass reading completely off course as well as the ambient temp was sometimes dramatically wrong. I replaced the module in the overhead panel that I thought controlled the compass but it did not help but a new ambient temp sensor seems to have fixed that issue.
Other than what I have mentioned the truck has no mods or replaced parts. I have opened the TIPM and seed no signs of damage or corrosion but I cleaned it all thoroughly and put it back together. I see no visible signs of bad wires and I am now thinking that the BCM has to be the problem. I found this forum and figured that I would see if anyone here has experienced anything similar. I have searched everywhere and can not find another documented problem like mine. Everything related to "Battery Saver Mode" talks about the intake heater on the Cummings so I get no help there.
I have a OBDLink EX cable coming for my laptop as well as the Chrysler FCA Authorization Gateway Security Bypass Cable and plan on getting AlfaOBD as soon as the others arrive. Ordering a new BCM tomorrow unless I get some solid info from you all here.
Any help at all would be greatly appreciated.
