2018 RAM 1500 shock replacement mileage?
Las Animas County Colorado
2018 Crew Cab 4x4 Big Horn
Hemi 5.7 V8
40K the next big mileage turnover. When will we need to replace the OEM shocks? And with what? We tow a small (15"/2000 lbs) travel trailer once a quarter. (BTW Ironman ATM tires rock.)
kurek
Northwest
There's not really a prescribed amount of mileage, conditions vary too much. People who live in cities with severely buckled streets (minnapolis, if I'm remembering correctly...) will tend to wear out shocks faster than people in cities with less buckled streets. People in extreme cold environments or who load their vehicles very heavily and drive in the desert will tend to wear out shocks faster than people for whom those things aren't true.
I'd be pretty disappointed if I didn't get 100k miles out of a set of shocks really.
If you're going to DIY the work, now or in the future don't forget that you will need either a 21mm crowsfoot wrench or the Thuren rear shock tool to remove the upper rear shock mount nut. No way to get at it with a regular socket or wrench, with the bed on the truck.
Probably the most popular shock replacement on these trucks is Bilstein - they make a number of different grades of shock for the 4th gen 1500 from the "HD" stock replacement shocks (yellow and blue) and 5100 (silver, front ride height is adjustable from stock up to 2.8" lift) to some remote reservoir rear shocks and the larger 6112 grade premium front shocks. The "HD" and 5100 shocks are constructed exactly the same as each other the only difference is the paint color on the HD's and the adjustable ride height on the 5100's
There's no shortage of other choices too, if you're not picky about it and just want the next set to last a long time with minimum cost you can't go wrong with KYB.
fijicorey
Orlando, FL
I replaced my shocks at 60k miles with KYB Excels. My ride noticeably improved. It's easy to do with the Thuren tools. All four shocks were about $150.
I replaced mine since I noticed my ride was choppy and a bit rough. The new shocks have fixed this.
Bob Glovik
Austin,tx
I am looking to replace/upgrade my stock shocks as well
I have 62K on my 2017 Ram 1500 2wd lonestar
I want to buy Bilstein 5100 series, but open to KYB or other performance/HD shocks
HuskerRam
Air Force
Tucson, AZ
3.0 Ecodiesel
My rears were leaking at 45k miles...replaced with Bilstein 4600s. Just saw my fronts are leaking now (54k miles)...will be replacing them soon.
6speedcummins
N. Dinwiddie, VA
I replaced the shocks on my 2500 at 120k miles with Bilstein 4600's and the ride is much smoother. When it's time for my 1500 shocks to be replaced I'll get Bilstein's for that one too. As far as replacement interval, standard recommendation is around 50k miles. But with frequent towing and/or rough roads 40k miles those stock shocks are probably done in.
