2018 Ram 1500 SLT Grease Fittings
Dan Topp
Jefferson Wisconsin
Even my new bend pac did away with the grease fittings that my 14 yr old same model lift has. Since the last ram I had before this 19 was a 86 I wonder when they stopped.Ive been using a needle grease adapter for decades because of the rack boots on the eldorados,but work great if you plug the hole.
Runaround
Silsbee
There is one on the upper end of the front driveshaft on the 2500’s, I don’t know about on the 1500. This particular grease fitting requires the use of a needle adapter on your grease gun.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Stock 4 wheel drive Rams have only one grease fitting
its on the front drive shaft & difficult to find
