2018 Ram 2500 Diesel
Mtl-Biker
Canada
Hi
i want to bought a Ram and when i check the sheet of the truck its said my tranny is (DG7) it is a "68rfe's ???
Thanks
Mario
mtnrider
Georgia
DG7 is the 6.7 cummins with the 68RFE transmission.
M
Mtl-Biker
Canada
ok i saw a lot of comment in youtube that said thats not a good tranny the 68RFE it is true?
M
Mtl-Biker
Canada
The 68RFE is fine as long as you leave the truck stock. Its the guys that tune and add horsepower that start having issues with it.
Ok it make sense i was nervous to bought one with that tranny
Thanks
Mario
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Just don't neglect to service your 68RFE with mopar filters & fresh ATF+4 fluid.
Drive like a civilized human being & it will not let you down.
Also Look Into - Installing one of these!
It will drop your transmission temps down at least 30*F.
https://www.dieselpowerproducts.com...ypass-valve-delete-13-18-67l-ram-cummins.aspx
Especially if you plan on towing med to heavy loads - Lower transmission fluid temps are Always a positive for longer transmission life.
MADDOG
Living in a Firepit
6.4L HEMI
And with some simple mods the 68RFE does just fine with a mod or two added to the Cummins.
Reactions: SyN
Sonoman98
Gillette Wyoming
6.7 cummins
Don't forget that means you have the low hp cummins (800ftlbs) not the high out put (930ftlbs).
half_crazy
Southen MD
Not sure where to put this...
I have a 2018 Ram 2500 w/Cummins and 68RFE. On Saturday, out of the blue, while slowing down when it shifts down to 4th there's a distinct clunk and the truck lurches.
It never did this before and everything else seems fine with the transmission, it's just that one downshift into 4th. 23,000 miles on the odometer. The most I tow is a 6000 lb trailer. The truck isn't abused.
Has anyone experienced a similar symptom? Not having a lot of trust in dealership techs, I was hoping someone could provide a little insight before I take it in for warranty work.
mtnrider
Georgia
Never had that happen before and haven't heard of anyone else experiencing it either? I'd just keep driving it and see if it happens again. The only thing I've had go wrong with mine was a failed shift solenoid (which ended up becoming a recall later on) but that was fixed prior to 2018 models.
half_crazy
Southen MD
Thanx for the response. I thought it might be something in the ECU so I disconnected the batteries for a while... no love, still does it.
RamCares
n/a
n/a
Hey half_crazy,
We certainly understand why this may be concerning. Please let us know via private message if you decide to have your dealer look into this. We would like to have this documented and have a case escalated in your behalf so a Case Specialist can work with your dealer to help find a potential solution.
Mark
Ram Social Care Specialist
half_crazy
Southen MD
Hey half_crazy,
Mark
Oh, it's going to the dealer as soon as the holiday weekend is over. I'll let ya know. Thanx.
RamCares
n/a
n/a
Hi half_crazy,
Thank you for the heads up. Did you get a chance to take your Ram to your local certified FCA dealer? If so, feel free to send us a private message as we would be happy to provide an additional layer of assistance during this process.
Mark
half_crazy
Southen MD
Hi half_crazy,
Mark
Sending a PM now...
RamCares
n/a
n/a
Sending a PM now...
Hey half_crazy,
Thank you for the heads up! I just responded to your most recent PM but wanted to touch base with you here as well. Please take a moment to review my message at your earliest convenience. Hope to hear from you soon.
Mark
half_crazy
Southen MD
The re-flashed it and it seems fine. Actually, it's better than the flash that came in it. Trans seems more precise/less sloppy.
