nlambert182
- Joined
- Dec 28, 2022
- Posts
- 2,657
- Reaction score
- 4,646
- Location
- Huntsville, AL
- Ram Year
- 2018
- Engine
- 6.7 Cummins
I don't know what it is. There are a couple of different potential failure modes.
If you mean just the truck by saying empty, then the truck didn't passive regen. It was most likely an active regen. For the truck to passive regen, you need to be working it hard enough that the exhaust get hot enough to clean the DPF without having to actively inject fuel to burn the soot off. Typically for soot to burn off the DPF temperature needs to be above 1000°FIt's empty
So, it could be the DPF after all?
Last trip it did a passive regen
For the Cummins you probably need to be pulling a decent grade with a trailer weighing at least 10K-12K lbs.
Going to have to disagree that you need the truck loaded to do a passive regens, I can get my truck to do passive regens with truck empty/no towing of any kind in as little as 30 minutes driving nonstop at speeds above 45 mph, but then I also use a fuel additive that helps with regens...If you mean just the truck by saying empty, then the truck didn't passive regen. It was most likely an active regen. For the truck to passive regen, you need to be working it hard enough that the exhaust get hot enough to clean the DPF without having to actively inject fuel to burn the soot off. Typically for soot to burn off the DPF temperature needs to be above 1000°F
A passive regen is when the ECM is not making changes in the fuel mapping/timing to elevate the exhaust temperatures to burn of soot. Only way a passive regen happens is with enough load on the engine. Drive on the freeway unloaded and watch the DPF temp (EGT4) itt will probably hovers around 600°. Two ways to get that temperature to go up, either a good load on the engine or an active regen.I can get my truck to do passive regens with truck empty/no towing of any kind in as little as 30 minutes driving nonstop at speeds above 45 mph
Take it.The dealership where I bought the truck, new, wants to buy it back from me. I think maybe I should take them up on that. What do you think, Mr. Lambert? I've had my fun with it.
I don't need this much of a truck to go fly fishing in Utah. My dad always said my eyes were bigger than my head.
My self don't care how it happens or what the ECU does, but when I see my DPF gauge drop from showing 25% down to zero while driving the truck unloaded too me its a passive regen and have been able to do so regularly since I started using Archoil 6400d & 6500 fuel additives, before I stared to use it I was lucky to drive 300-350 miles between soot loaded regens, now with using Archoil I can go a full 24 hours between regens.. I've also heard that Pittsburgh Power also has a fuel additive that will also help with regens but have not tried it or talked to anyone who has so cant comment on it...A passive regen is when the ECM is not making changes in the fuel mapping/timing to elevate the exhaust temperatures to burn of soot. Only way a passive regen happens is with enough load on the engine. Drive on the freeway unloaded and watch the DPF temp (EGT4) itt will probably hovers around 600°. Two ways to get that temperature to go up, either a good load on the engine or an active regen.
I don't even think downshifting and holding close to 3K rpms would generate enough heat.
If Regen is happening at 45 mph I'd be willing to bet that the ECM is changing the fuel map/timing to elevate the DPF temperature, if not you'd wouldn't be able to cruise at 70 mph for hours without being in a state of constant regen which eventually would shorten the DPF life
I use Archoil 6400d system cleaner, then Archoil 6500 additive in every tank....Please tell me. What is the fuel additive you use that helps with regens?
Watch this U-tube video I found and watched it, I was surprised to hear that the top 2 diesel additives are Archoil and Hot Shot every day additive. FYI Power Service paid Cummins to get there approval to put their name on there bottles just like Valvoline did for there diesel oil, just because it has Cummins name on the bottle does not mean its the best...
So your making the assumption it's passive but in reality the ECU is controlling the DPF burnoff. Fuel is injected during the exhaust stroke so the fuel vapors burn and elevate the DPF temps.My self don't care how it happens or what the ECU does, but when I see my DPF gauge drop from showing 25% down to zero while driving the truck unloaded too me its a passive regen
Only way to know your doing a passive regen would be to monitor the EGT4 temperature regularly while just driving then comparing that to while loaded. For a passive regen to happen the first four EGT sensors will all be playing with 4 digit temperature readings.
Even as light duty as the EcoD is compared to the Cummins, it takes an 8K load pushing against headwinds while traveling 60-65mph for passive regen to happen.
Don't know how your Eco emission system works but in my truck it will show on EVIC if my truck goes in to a regen mode, be it soot load or the 24 hour regen ( I have many different photos over the past years of the screen showing when its in a regen mode) as I have been told by those who I trust an those work on theses engines that the ECU only time it add extra fuel is for soot load and 24 hour regens, thus any time the soot load goes down without the auto regen message showing its doing a passive regen, that means the DPF temp has reached a hi enough temp to burn/reduce the soot load in the DPF... I'll attach one of the photos showing the message I see for auto regen. BTW I time my regens so I know if its a 24 hr or soot load regen...So your making the assumption it's passive but in reality the ECU is controlling the DPF burnoff. Fuel is injected during the exhaust stroke so the fuel vapors burn and elevate the DPF temps.
dordoc2506 Well we're still waiting for you to tell where you get these genuine Mopar filters for half price.
