2019 Dodge Ram 1500 Classic Tradesman ( turn signal and puddle light not working )
Jlopez_2015
Indiana
5.7 V8
So i ordered brand new after market turn signals and puddle light for my 2019 dodge ram, before i replaced both the signal lights and the puddle light the puddle lights were very dim. The turn signals dint work at all. Once i installed the new ones they dint work at all any one have this issue?? These are the ones i ordered. I did check all my fuses and everything.
D-Lumina LED Side Mirror Turn... https://www.amazon.com/dp/B0CPTQCR1R?ref=ppx_pop_mob_ap_share
Atcer2018
Virginia
Prior to replacement the turn signals didn’t work and the puddle lamps were dim? Have you checked voltage output from the wiring harness?
Jlopez_2015
Jlopez_2015
Indiana
5.7 V8
I have not, i ran out of time as it started raining. But if i have low voltage what steps would i need to take after?
Atcer2018
Virginia
Making sure it has power and the appropriate signal to activate the lamps or turn signals is the first step. Low voltage can be from a number of things that will have to be traced back through the wiring. Corrosion, faulty switch, relay, ground are all suspect.
millersnmeva
Virgnia
