2019 Laramie
chrislewis6568
I’m hoping somebody out there can let me know I have a 2019 Laramie with air suspension and I want to put it 2 inch lift all away around so I can put 35 inch tires on it there’s anybody know if this is possible yet and if so can you hook me up with website that may have the 2 inch lift
BadHabit57
Missouri
I've seen the Mopar 2" lift on a truck here, I would look into that maybe?
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Someone correct me if I am wrong but I don't think there is an actual lift for the air suspension equipped trucks.
I have seen people change out the end links on the air suspension to fool the system into thinking off road 1 is actually normal mode.
mathews8pt
Yea, that’s the easiest way to get just a little more height for tire clearance. Not a terrible idea to check alignment if you do a full 2” up front. I’ve done it to my wife’s 15 and not much of a change in ride when the larger tires are taken into account.
