2020-2025 and still a soft brake pedal?
kbr577
Durhamville,NY
Ram 2500 HD 6.4
Over the past 5 years, no brake pedal feel improvement? My 11 Ram has a better feeling brake pedal feel than my Newer 2020, and 2025 trucks. Ram you haven't listened to your customers? Fix the ensuring brake pedal feel!! If anyone has any improvements let me know.
Thanks
etbrown4
Excellent brakes in a 24 1500!!
zrock
canada
Are you stopping? If you are then get used to the much lighter touch you need in the newer trucks.. If you want a hard pedal go drive a new GM has a hard pedal and does not stop anywhere near as good as my ram does.. Usually if i can avoid it i will not drive it i hate the brakes so much
Bearcatrp
My 2017 3/4 ton I used to own and my current 2021 3500 1st press of the brake is a little soft but when I press a second time right after the 1st time, it’s very stiff. Think it’s designed that way.
Replacement
Idaho
Hemi 6.4L
My 2025 is the same way. I don't prefer it but it stops just fine.
jaccard30
