2020 2500 Limited Headlight AFS Control Module
ToddT
North Carolina
I have a 2020 2500 Limited and the right side headlights (high and low beams), day running light, and turn signal went out at the same time. I noticed it has a module on the back called an AFS control module. The dealer says I have to get the entire headlight assembly to get the module. My question is has anyone else seen this problem? Is it possible to swap just the module instead of swapping the entire headlight? My current headlights are color matched and I know Chrysler will deny the warranty if they receive a headlight that has been opened even though that has no affect on the failure of the AFS module.
68Cudaconvert
