2020 Durango UAQ in 2017 Ram 1500
Av8er1555
Ohio
Just like the title says, would a 2020 Durango UAQ be plug and play with the USB hub for my 17 Ram? Goal is obv to get apple carplay
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
Does it even have the same mounting bracket? There was someone on here not too long ago that said they used a different dodge radio in a Ram and it worked but I think most people would say to not do that. You could always plug it in a see what happens.
Also I believe the USB hub would have to be upgraded to a 2018 version for CarPlay to work, but that’s with the Ram radio’s, not sure about this durango one.
18harvest
huntsville
You will need a different hub no matter what.the durango radio does fit I think but isn't a perfect fit.the top mounting holes are different.will it work? Maybe.i have used challanger radios that worked pefect in rams and I have a uaq ram radio now that the vehicle quide app doesn't work after an update.i would stick with a ram part number though.
Arturo Rojas
