2020 Ram 1500 tail lights out
Precisionhvac
Shady Spring WV
3.0 diesel
I've seen a lot of ppl on here with the same issue. I have no rear tail lights, but all other lights work, I have checked all my fuses, bulbs, and pins with my meter, like new, no corrosion all fuses have continuity and all the pins that need ground have ground and pins that need voltage have voltage. This being said, I've seen this issue repeatedly here, has anyone found a solution or at least the issue?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If you have any Warranties, i would go to the dealership,
If you have not changed the lights or sockets
change anything back to how it left the Assembly Line
Or find a Good Auto Electric Shop, one that works on Classic vehicles & Hot Rods
