I just purchased a 2020 Ram 1500 Big Horn with the V6 and 3.55 gears in the differential. So far I've absolutely love the truck. It has plenty of power for my needs. One thing I've noticed that feel a bit irritating is the shift points. If I'm cruising down the interstate at 80 MPH, the truck is in 7th gear most of the time running at about 2,600 RPM's. It will shift into 8th gear and drop to about 2,000 RPM's. If I run the truck at like 85 MPH, it will consistently be in 8th gear (however, I would end up with a ticket). The roads I drive on are not overly hilly (wisconsin rolling hills).
I've read a lot of complaints about delay in the gas pedal, and how a device like a pedal commander make an improvement. I'm wondering if a device like a pedal commander would help the truck find 8th gear, or is this simply an unrelated issue?
