2020 Ram 2500 Laramie right rear brake light.
SteveCallen
Florence Ky
I have a 2020 Ram 2500 Laramie night edition with LED tail lights, my right rear brake light isn't working. I pulled the housing, nothing looks burned, all prongs in the plug look good, from what I could tell the wiring inside of the housing looks okay. Truck does have 4way/7way plug at the bumper, as well as the plugs in the bed for a fifth wheel / Gooseneck. Any ideas? Thanks
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
What were the voltage readings at the plug when you tested it? Also did the ground have continuity? If YES to both, then it would come down to the taillight which I don't believe is serviceable. Maybe, (fingers crossed) it would be covered under warranty if you still have one.
BGW656
