2020 Ram 2500 Tradesman Chirping sound interior.
Jdgautreaux
Louisiana
6.4l
FOUND THE CHIRPING NOISE – 2020 Ram 2500 Tradesman (Manual 4WD Shifter)
Posting this to help anyone chasing a random chirping noise that happens with vibration.
Truck: 2020 Ram 2500 Tradesman with manual floor-shift 4WD
Symptoms:
  • Chirping noise while driving
  • Happens with road vibration, not engine RPM
  • Sounds like it’s coming from everywhere (very hard to pinpoint)
How I confirmed the source:
While driving in 2WD, I applied light forward pressure on the manual 4WD selector handle (did NOT shift out of 2WD).
The chirping stopped immediately.
Root cause:
The noise is coming from the manual 4WD shifter / linkage vibrating. Slight play in the linkage or detent lets it resonate and chirp over bumps or vibration. Applying pressure preloads the linkage and stops the noise.
What it’s NOT:
  • Not belts or pulleys
  • Not suspension
  • Not brakes
  • Not engine noise
Next steps / fix ideas:
  • Lubricate shifter pivot and underbody linkage
  • Inspect/adjust linkage for excess play
  • Check bushings or add isolation where needed
If you have a Tradesman with the manual 4WD floor shifter and a mysterious chirp, try this before tearing your truck apart.
Hope this saves someone time and money.
turkeybird56
Central Texas
Nice catch OP
Elio
Florida - FLX Central NY
Hemi 5.7L e-Torque
HI, I was just about to post similar post but with 'Ringing' sound but in my case it's sound only when i roll my windows down and while driving slow MPH (20-30), so the sound apparently is exterior. My truck is 1500 5.7L Limited. Should I assume your fix ideas apply to my problem? thanks for posting.
