2020 RAM Air deleted & Lifted AlphaOBD help
WinstonMcG
Indianapolis
I have a 2020 RAM with factory air suspension. I removed the air struts and installed 6” lifted coil overs, removed rear air spring and installed 6” lifted coils. Installed the OE insulators on top of the springs. I capped off all of the air lines just to prevent moisture from entering the system.
I am to the point where I need to take care of the electronic side of things & I need assistance - **get rid of the ‘Service Air Suspension’ messages etc.** Here is some information that will help others delete factory air suspension. I also need some help - so please chime in :)
After installing a 6” kit (kit designed for 19-24 RAM 1500 with 22” factory wheels w/o factory Air Suspension). YES - these kits will bolt right up! The ONLY thing needed in addition to a complete kit is the spring insulators for the rear springs. In addition to this you will also need to do the following:
- purchase AlphaOBD.
- connect AlohaOBD device (laptop, in my case) to vehicle’s computer network. I use a J2534 device (Autel MaxiFlash VCMI) via OBD/DLC port.
- IMPORTANT NOTE: you cannot just plug into the OBD port & expect AlphaOBD to work. FCA requires you to purchase a subscription in order to access their vehicles/get past the security gateway. You will need DIRECT access to the CAN C & CAN IHS networks in order to use AlphaOBD. This can be done by purchasing kits or plugs. It can also be done without purchasing plugs. You basically need access to CAN C & IHS on the other side of the security gateway. With this truck (and MANY Chrysler products of similar years) you can access the CAN C & IHS bus bars inside the dash in 5 min. You’ll need to remove pins 6 & 14 from the OBD port. Using the same style of pins you’ll have to run wires from the CAN C bus bar to pins 6 & 14. Do the same thing from the CAN IHS bar to pins 3 & 11. I used a breakout box that was plugged into the obd port (after removing pins 6&14) - much easier IMO.
PIN INFO:
3 - IHS+
11 - IHS-
6 - C+
14 - C-
Once you have AlphaOBD connected to the vehicle & with direct access to CAN C & IHS you will be able to use AlphaOBD to it potential.
Here’s where I am at. I can access tons of menus and sub menus. When I access the ASCM one of the options is “Disable ASCM”. When I select this option and choose ‘Start’ I get the “Failed” response in the box below the list of options. Is there a reason for this? Is this not the correct option? What module do I need to select in order to tell the computer this truck does not have factory Air Suspension that way it’ll stop throwing codes? I’ve seen videos and read forums on older RAM trucks but the menu options others’ have mentioned do not exist in my AlphaOBS lists. There’s gotta be a way to do this on gen 5 rams, right??
RamDiver
Marlborough, Ontario Canada
2021 DS
That sounds like an awful amount of effort to mess up your OBD interface and apparently doesn't accomplish the task.
Most of us with a 2018+ Ram just buy a KaodTech security bypass cable.
It takes a couple of minutes to install and can remain tucked up behind the dash while your OBD interface is not mutilated and is available for use at the Stealership.
https://kaodtech.com
And, welcome to Ram Forum. :cool:
CanRebel
Toronto
Just buy a by-pass cable or module. There many different ones. I have 6 of them. I use ZAutomotive module the most.
Going to take guess. it's not working because your not actually by-passing the security. I'll admit I haven't disabled the air suspension on my rebel. So could be different issue.
W
WinstonMcG
Indianapolis
Thank you. I’ll get the cable ordered, it’d definitely be easier . I am able to change/modify many parameters, turn items off (seatbelt lamp), etc. I’m just not finding the menus/submenus I believe I need. I suppose the ‘Failed’ response in Alfa when selecting ‘Disable ASCM’ is also an issue I can’t get past. I’ll start with the cable and see if it helps.
W
WinstonMcG
Indianapolis
UPDATE
Holy Cow!! AlfaOBD is the best!!! I’ve used forscan for fords for some time (that was a mouth full!) and it does not come close to AlfaOBD! The amount of access you have with Alfa is amazing!
After finding the correct menus I was able to get the “Service Air Suspension Immediately” message to go away and stay away. > BCM > Car Configuration Change > (changed a handful of items from this point - the most notable being the option to disable the air suspension service message lamp).
Appreciate the help!
RamDiver
2021 DS
UPDATE
Did you copy your current configuration before making any changes?
That's a SOP that is strongly encouraged so that you have a baseline to fall back to.
Many of the AlfaOBD tweaks have been successfully completed without any issues but occasionally a simple change might have unexpected consequences.
I once changed a simple cargo lighting feature and killed the power steering.
I keep a detailed change file on my PC and make current configuration backups often.
HunterStover
Virginia
PIN INFO:
3 - IHS+
11 - IHS-
6 - C+
14 - C-
PIN INFO:
3 - IHS+
11 - IHS-
6 - C+
14 - C-
I read the whole post and I’m debating on an air ride delete, you still got the truck and are you still active if so I think you could help me out!
RamDiver
2021 DS
The member you quoted was here for only 2 days, almost a year ago.
If you're looking for recommendations, post your details.
HunterStover
Virginia
Thank you, confused on some of the air ride delete options, one offers a programmer you plug in and delete and be done I believe? Another one offers a little module that you splice some wires and leave it. I personally prefer program it. Also looking to lift it with a 6 inch bds lift
RamDiver
2021 DS
You're most welcome.
The search utility in the upper right corner will assist in locating many threads on this and other topics of interest.
@Nick@GotExhaust, a member here, can supply a quote and provide recommendations on various lift options to meet your needs.
Nick@GotExhaust
Supporting Vendor
SC
tspirawk
WI
This feed is a few months old but figured it best to not start a need thread.
I have a 2018 RAM 2500 Limited. I have removed the rear air suspension previously and just now getting around to using alphaOBD. I got it all hooked up, successfully connected to the body module, and made the changes. Or so it said. However I still receive the "Service Air Suspension Immediately" error code.. I did clear the fault, but it reappears. I set ASCM air suspension controll monitor has suspension to No. Set Air Suspension Warning CSM Present to No. And set active dampening to No. I did remove the 40 amp fuse as well.
Any ideas what else I'm missing? Thanks in advance. I am using AlphaOBD on an Android phone.
RamDiver
2021 DS
I have no experience with tweaking for air suspensions, but one setting that I have to question is the 'Cust.Set.Menu 1-Air Suspension Warning CSM Present' set to no.
The CSM is the customer settings menu in the Uconnect radio.
If this setting were set to 'YES', you could deselect the warning to deactivate it.
Have you tried it configured in this fashion?
tspirawk
WI
I have not. I will try that today and report back with findings
Thanks for your input.
RamDiver
2021 DS
Did you also scan the results from the search link in post #10?
It contains links to several suspension delete threads. Given that these search results are dated from last October, you might try your luck with a new search today.
Try the search utility in the upper right-hand corner.
tspirawk
WI
I made that change, but it doesn't help. I will continue to go through those links posted in post #10. I did go through some of them. If I find a solution, I will post it here to help others in the future.
tspirawk
WI
Ok, I just resolved my issue. I did the conversion last summer and just now got everything to do the alphaOBD steps. I discovered that I removed the relay so the air compressor wouldn't run, but I didnt pull any fuses. Once I removed the three fuses the error went away.
So for anyone else, remove
F5 (40 Amp): Compressor
F50 (20 Amp): Control Module
F87 (20 Amp): Air Suspension
Relay 3: Air Suspension Relay
alphaprojects
