2021 Ram 1500 hemi shut off when driving
BigTom63
Long Island, New York
2021 Ram 1500 hemi shut off when driving. Stuck on side of road. Cannot restart. Multiple errors on dash including check engine, airbag faults etc, abs fault, radio anti theft on too. Cannot do anything. Anyone have a suggestion. Cannot even get out of park.
MADDOG
Living in a Firepit
6.4L HEMI
Try a battery(s) negative cable disconnect. Leave it disconnected for 30 minutes.
While waiting check the main harness connection to the PCM, plus all your main power positive and ground connections (starter, battery, body, etc....
Once you connect the battery(s) then give it a go.
Good luck!
It might be worth a look on the driver's side under the truck around the back of the front tire, maybe inside the frame rail, look for a large wire harness that may be slightly separated.
B
BigTom63
Good luck!
Thanks. I got a flatbed tow to the ram dealer. It will sit till Monday so I will try and do that while it sits tomorrow.
B
BigTom63
Thanks was flatbeded to dealer but will take a look tomorrow since it won’t be looked at till Monday.
RebelHawk
SouthEast USA
'22 Hemi 5.7 eTourge
I had similar thing happen to me that I posted in the Engine Performance forum here. 2022 1500 eTourge, A week ago I was under heavy acceleration merging into interstate traffic when my dash lit up and engine shut down. I coasted to side of the interstate and powered everything off. Let it sit for a few minutes and mine did start back up but the check engine light stayed on. I drove very reserved for the remaining ride home. Called local dealer who can't get it in until next week but after letting the truck sit for 2 days the check engine light went off by itself. I'm keeping my dealer appt for Monday to let them look at it and tell me what happened.
DaGoose
Canton, IL
What did you find out??
Kickboxer
ND
5.7 Hemi-non-Etorque
Get AAA and call a tow truck..........
Thmw
Conroe TX
5.7 Hemi e-torque
Within the last month a recall was issued by RAM for this very purpose. I also had 2 random shut downs. It is recall 37A and takes about 2 hours to reprogram the onboard truck computer.
Glowz
