2023 1500 BigHorn 4x4 Leveling Kit
JWA984
Beaumont, TX
5.7L V8
I recently purchased a new 1500 BigHorn crew cab and I'm thinking about a leveling kit. I'm undecided on if I should go 2", 2.25", 2.5". I want to keep the OEM 20" wheels but I do want to replace tires with A/T's... thinking 33's but may consider 35's. Looking forward hearing everyones input. Thanks.
KYPOTLICKER
Kentucky
I am a broken record on this topic. I would go 2 inch level. Fox or Bilstein 6112. 275/65/20 on stock 20" rims look good to me, I am biased. Nick@GotExhaust on this forum is a reputable dealer and can answer any questions you may have, along with supplying needed parts at a good price.
J
JWA984
Beaumont, TX
5.7L V8
Is that what you have on your truck in your profile pic? If so, that's spot on to what I'm wanting.
J
JWA984
Beaumont, TX
5.7L V8
KYPOTLICKER
Kentucky
Yes. I went with the Bilstein 6112 shocks/spring up front. Ring 6. I am within 1 inch of level front to back.
275 65 20 Recon Grappler, largest P rated tire I could find with a good look. I do not tow heavy or do much off road.
Very pleased, again can not recommend Nick@GotExhaust enough.
J
JWA984
Beaumont, TX
5.7L V8
Thank you for the input...I really appreciate it!
hubbard
Southern California
Hemi V8
I agree. I have a 2017 Longhorn and went with the same 275/65/20 P rated tires. After a couple of months, I love these tires. I had to remove the failed four corner air suspension and went with the airdelete.com Eibach kit which got me a 3" lift up front and 1.75" lift in the rear. Even without the air suspension ride, the new Eibach system with the Recon Grapplers make for an excellent ride.
Arturo Rojas
