2023 Ram 1500 4x4 Big Horn Etorque
JWA984
Beaumont, TX
5.7L V8
Hi all, I have a 2023 Ram 1500 4x4 Big Horn that has the 5.7 Etorque. So far, the only thing I've been able to notice is starting and stopping... a bit "jerky" if that is the correct terminology. Has anyone else experienced this? If so, what has or can be done?
JoshsRam
Lake Forest, CA
5.7L
I am pretty sure it's normal. I get it on my 2021 as well (though mine is 2WD). The best way I've found to mitigate it is, after coming off the brake and the engine re-engages, to give it 1-2 seconds before I roll into the gas pedal.
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
It's normal, especially if you are quick on the throttle as the engine is starting.
It is w-a-y better than traditional start/stop that uses the vehicle's starter. RAM claims 400 msec to initiate starting with the BSG (Brake Start Generator) that sits in place of the alternator.
It is very noticeable going between non-eTorque (my RAM) and eTorque (my dad's RAM).
To mitigate that you can gently pump the brake to start the engine when you know you are about to go. This will get the engine running for a bit so you don't have to wait for the engine to start to get rolling.
You can also be a little slower between the brake and gas pedal as JoshsRam said to give the engine time to start before you give it gas to go.
lezmark7
Keller, Texas
2023 Big Horn 1500
like he said - I have the same truck - love it BTW
DanAR
Arkansas
Same here - I just pause a split second after releasing the brake before I move my foot to the accelerator. The brake pumping idea is a good one too.
Dean Sao
Los Angeles
Yes, I have the same vehicle just takes time to get use too.
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
you can also press the button and turn off the auto stop feature. Surprised nobody said it yet!
Tow/Haul will turn it off also.
I read the OP's post as wanting to know if the feature is operating normally on their truck or if they should have it looked at...not how to disable it.
Just my .02
suicideking
Riverside, CA
This is what I do. I've gotten into the habit of pressing that button every time I start the truck.
When I test drove it, the salesman even told me I should turn that off every time or it will wear out the starter faster. I'm just not a fan of the auto stop/start. I might turn it back on if I was at a train crossing or another extended stop.
kirk35
Navy Badge
Ocean Springs, MS
6.7 CTD Tradesman
Your salesman doesn't know what he's talking about. The starter isn't used to re-start the engine.
sblack33741
Maryland
3.6L Pentastar ETorque
Same here. I can tell you that it is faster than my wife's 2019 Highlander. That stop/start system is quite delayed.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Not sure how this can be considered normal. Although they did make some changes to the system over the last couple years, the last Etorque I drove was the 2021 Limited I used to own. Before that I had a 2020 Laramie w/etorque. On both of those trucks I really had to try to get my foot from the brake to the gas before the engine was restarted. In normal driving it wasn't noticeable other than the sound, since both had aftermarket exhausts. It was very fast and seamless on both trucks. Now you guys are saying it's slow enough to notice a delay? So glad we no longer own an etorque equipped truck.
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
You do have to be pretty quick to beat the restart...but if you don't have eTorque it is noticeable, especially if you are trying to merge into traffic from a stop.
No members online now.
Fryekenn
