2025 RAM 1500 with factory raised ride height
D_Rud
Idaho
Who has a 2025 RAM 1500 with the factory raised ride height w/o air ride? I want to lift it 3-4" and fit 35's w/o rubbing. I can't seem to find a compatible lift kit? Rough Country says theirs is not compatible with the 1" factory lift. ReadyLift says the same thing.
olyelr
Kewadin MI
Im sure any kit will work, just might be an inch less lift then they advertise.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
The BDS and Zone kits work with the factory raised 25 Rams. 4” with 35’s looks perfect on the 2025’s we did the first one on the planet June of 2024.
D
D_Rud
Idaho
Would the 2” Zone leveling kit SKU: ZOND2301 work with my 2025 RAM 1500 with the raised ride height? Would this raise the front a total of 3”
Nick@GotExhaust
Supporting Vendor
SC
That part number is for UCA's, not a leveling kit. They are used for 2-3" of front lift to correct the front end geometry from leveling.
I think you may be thinking of the D70. I do not recommend that type of spacer leveling kit. That is not the best way to level these trucks. Spacer kits have proven to be an issue on these trucks especially in the long run. Are you looking to any raise the front or the front and rear?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
You’ll spend the money to get a leveling kit then you’ll be asking why your 35’s rub and eventually you’ll buy a 4” kit and love it. Skip the leveling kit unless you want a smaller tire. I’m in the business I see guy pay me 3 to 4 times installing the next level every time then say. Yeah you were right and I say yes you’ve spent $9k in the last 5 years we could have done the lift and wheel and tire package for the money you wasted chasing a look every one told you how to get.
D
D_Rud
Idaho
Nick, you are 100% correct on the Zone leveling kit for a 2025 1500 with the "off road pkg" raised ride height. I'll order that from you. What wheel and tire package would you recommend. Zone recommends 33x12.5 but that does seem a bit small? I'd like to go with a 20x9 wheel. What is the optimal offset? Would a 295/65/20 work?
phorrestphire
