2500 CC payload?
6.7CumminsDrvr
The Dude abides………
Georgia
So I am contiplating moving back into an HD but a gasser this time. I really wanted a PW but the payload is no better than a 1500. Soooooo, what are the actual payload numbers posted on your door jambs? The stickers are always lower than the stinking max values in any literature you find. TIA! :favorites13:
Looking for a 2500 CC 4x4, 6.4 Hemi, most likely loaded.
Ratket
Arizona-
my big horn mega " no leather and no sunroof" has a payload of like 3300 pounds.
6.7CumminsDrvr
6.7CumminsDrvr
The Dude abides………
Georgia
That's what I'm talking about!
I know the PW is built for offroad and has a lower GVWR but I seem to remember the previous gen had like a 1900 lbs payload. Who knows, pretty sad they are so low. My buddy just got a PW and his sticker says 1272 lbs!!!
MADDOG
Living in a Firepit
6.4L HEMI
My 2014 2500 Bighorn, CC, 6.4L HEMI specs:
Max Towing 12,590
Max Payload 3,180
GVW 10,000
GCVWR 19,500
6.7CumminsDrvr
6.7CumminsDrvr
The Dude abides………
Georgia
2014 Limited with all the goodies you can cram into it- 2760lbs payload for the 10000 lbs GVWR truck.
FWIW, there was a PW thread that had a payload of barely over 1000lbs.
Ya, I saw that one and i started poking around a bit. My buddy just got a Laramie PW and his sticker is only 1272 lbs. Kinda bummed, been wanting a PW for a long time
Ratket
Arizona-
Biggest thing I wish I could change is a stock option for 456 gears. - eventually I will just have it done.
SouthTexan
408 CTD
If you want the PW, but with the payload ability of a regular 2500 then why don't you just change out the PW rear linear rate coil to a progressive rate coil from a regular 2500. Both rear suspensions are basically the same besides the coil and shock. You can probably pick up an OE coil for about $200 each online or an aftermarket for a little less. Keep in mind that the sticker on the door will always be what it is, but you will not get in trouble by the law for going over that amount as long as your truck is registered correctly in the right truck class. Also your rear suspension articulation and wheel travel will go to shnit with the progressive rate coil too.
6.7CumminsDrvr
6.7CumminsDrvr
The Dude abides………
Georgia
You and I think very much alike:favorites13: My concern is we live in a society that can't seem to follow logic and apply common sense to something like this. And if I ever had any problem, warrenty or civil, I would get the "you were over weight blah,blah,blah......." and hung out to dry.
Still temping, love the PW!
RoadDog66
Western MD
15 c.c. laramie with sunroof, loaded etc, 6.4, 3049lb door sticker
That's odd, my CC BH 4x4 with moonroof, prem cloth heated seats, 8.4AN, W2W steps, etc has a 2920 lb payload. Maybe the 20" wheels take away from payload. Guess i need to go on a diet.
coguzzi
none
none
difference is probably heavier 20" wheels and the steps, seems to be roughly about a 100lbs give or take. every option does removed from the capacity--think about what sliders and such do at 500lbs. leather vs fabric--negligible weight difference (i do upholstery part time for a living).
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
My new rig has a moon roof, Cummins, CC, long bed and I'm at 5,713 payload and 18,550 pull.
mike456
new york
cummins 6.7
im in nyc, headed out to western pa two weeks ago to pick up a load of pipe i needed, about a 5-6 hour ride.
load was 3300lbs on the dot. i was cruising between 85-95 mph the entire way, or until i got to nj, what a pleasure to drive.
those 2-3 mile inclines were a breeze, i couldnt ask for more, never needed to rev high, just maintained speed without an ounce of effort
tim57
SW MI.
2015 Power Wagon
My 2015 RAM 2500 POWER WAGON LARAMIE CREW CAB 4X4 3,152 payload, 15,500 pull.
According to my VIN tow/payload chart.
SouthTexan
408 CTD
You must be reading the wrong chart.
Stangshcky12
Oshkosh, WI
5.9 Cummins
8,000 truck loaded 1,300 lbs over GVWR going 15-25 mph over PA's highest posted speedlimit
New York drivers for ya
