285/75r17 on 21 stock warlock rims
TorquedGyro
Canada, BC
I can't seem to find a clear and definite answer on this because everybody is running aftermarket rims but if I get a set of 285/75r17s on my stock warlock rims with no spacers or lift, 100% factory, will I get any rubbing. The truck is new enough still I don't want to modify anything and I'll go 285/70r17 if its going to rub.
Hambodian
Puyallup, WA
2019 Classic Warlock
Seems like it should be fine. Looks to be only 0.5" wider and less than an inch taller than what came stock on my 2019 Warlock which is 275/60R20.
SD2020
Canada
Not sure in your exact case, but my 2011 has 285/75/17's on stock rims, but I run 5100 shocks at 2.1" . No rubbing but the tire sidewall is close to the upper a arm, like an index finger width, but it has never touched and I drive fast and off road with it a bit.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Op
My 24 warlock, classic I'm running 315 70 17 s with no rub.on stock warlock rims
Central Ohio
2020 Classic
Any idea if warlock wheels are the same dimensions as the Classic 17s? I'm due for new treads and I want to go larger than the stock tires on it now. Are you at stock ride height other than the larger tires?
Central Ohio
2020 Classic
I don't know the width of mine. Haven't looked it up or measured. mine are stock 1500 classic 17" wheels. I would imagine they're 17x8, I don't know that anyone has made truck wheels skinnier then that in quite some time. I was more interested in the backspace/offset anyway. I should be safe with what I ordered. Only 1" taller and 3/4" wider than the stock tires. Hopefully by the time I need tires again, I'll have gotten motivated and done a level kit to the truck with the adjustable front shocks, then I can go 33" or 35" like I had on my 2500.
This 1500 looks like a low rider to me, yet it's still a 1/2 ton 4wd truck!
ChloeBrooks
