2inch level
Rochellemj
4.7 magnum
I have a 2004 dodge 1500 2wd reg. Cab. I'm planning on putting on the rough country 2 inch leveling kit, but will it level it out good or will there still be a noticable dip in the front? Let me know what you think
usaf2006
North Carolina
Depends on a few things. Are your springs wore out? Shocks wore out? If those are shot, a leveling kit may not level you. Grab a tape measure and measure from the ground to the fender lip, centering the tape measure on the center of the rim. Subtract the front from the back and that'll give you an idea how much you need to get a true level. If it's over 1.5", it's likely you need shocks or even springs. I was at 2.5" difference, then I Installed my new Monroe struts (4wd) up front, and now I sit at exactly 1.5" difference.
Hope that helps some.
