2wd leveling kit
wickedwhite2012
Baton Rouge
Can someone in lighten me. Im thinking about putting a leveling kit on the front of my truck. Was thinking about the 2in spring spacer. If i was to do this i have to put longer shocks in place of the factory shocks?
RyanJM
Houston
2014 Express RC Black Edition
Go check out Maxtrac on here. Aside from spindle lift kits. They also sell a 2wd front level kit that is replacement springs rather than spacers. If you do use spacer as I did back on my 09 2wd I used pro comp es 9000's up front 0-3" lift and they were $40/each at 4wheel parts. There are better brands but those rode great I did all 4 and they were great for the money.
atc06jh
Middle Georgia
I posted a similar question myself on here as I have a 2WD also. I called MaxTrac Suspension and talked to Shaun. He said that their leveling kit for our trucks is all you need. No use for UCAs or shocks cause its only 2 inches.
joshhhh
