hey there,
so the spindles really work - without ANY problem???
my truck is a 2wd, too. right now i am stuck between two lift options which shall be done in the beginning of the next year.
1. 3" bodylift with a 2" leveling kit = 5" total in front and 4.5" in the rear (3" bl plus a 1,5" spacer)
2. 6" CST kit (which is about 1K $ more expensive and cause of that not that interesting at the first view
this thread led mo to another idea which i´d like to discuss with you guys.
what about the following option nr. 3/compromise:
buying the 3" lift spindles mentioned in this thread plus adding a 3" bl and a 1.5" spacer for the rear. this would make 6" in the front and 4.5" in the rear. that is the same setup CST haas (height wise), way cheaper and without the problems a 2" spacer in the front might cause. or is my calculation wrong (adding the bl and the spindle)?
would that work?
is nr. 3 better for all the parts than nr 1 because of the missing spacer or are 2" spacers ok/don#t influence the ride quality?
thank you so much in advance!!!
