2wd lift spindle question
bloombloom88
Plano, Texas
I'm wanting a 3 inch level on my truck, but as far as I know, using coil spring spacers will put more stress on your ball joints and shorten the life.
If I bought 3 inch lift spindles, will the same thing occur?
sausec17
Banned
ATLANTA
nope, not at all. suspension isn't altered with spindles :)
bloombloom88
bloombloom88
Plano, Texas
With lift spindles can factory length shocks be used or will I need new longer ones?
sausec17
Banned
ATLANTA
correct, 02-12 uses the same spindle. use stock length shocks.
bloombloom88
bloombloom88
Plano, Texas
Excellent, thanks for the replays. Will I need to extend my front brake lines? Anything else ill need to do when installing these spindles?
sausec17
Banned
ATLANTA
when you get a chance, take a look at your stock spindle set up, that will show you why it doesn't effect your ball joints and why you will need extended brake lines
bloombloom88
bloombloom88
Plano, Texas
Will do, I don't completely understand how it doesn't add the stress, but with a spring spacer it does.
sausec17
Banned
ATLANTA
its a diy installation for some, but alignment will most likely be WAYY off. make sure you don't have to drive TOO far
sausec17
Banned
ATLANTA
its hard to explain the geometry on the front end of these trucks lol youre not the only one who doesn't understand, I don't either. just what ive been told
bloombloom88
bloombloom88
Plano, Texas
Lol well I've heard what's been said as well, but hearing it and understanding it are 2 separate things..
I've done plenty of front end work on my old explorer, a spindle job should be cake, especially since I don't have cv shafts to deal with this time around
TexasRammer
College Station, TX
all the lifted spindles do is lower the point at where the hub attaches to the spindles, therefor lifting the truck. making it simple, its like lowering the point where the wheel is on the vehicle so none of the other suspension components are affected. When you add a spring spacer or longer coil springs, you increase the distance between the lower control arm and the top spring bucket. so then your control arms angle down more, changing the angle of all other suspension components such as the ball joints also creating a rougher ride and less travel
bloombloom88
bloombloom88
Plano, Texas
I understand now, thank you for clearing that up
sausec17
Banned
ATLANTA
bang bang...:head3:
bloombloom88
bloombloom88
Plano, Texas
So it's 100% sure that from 02+ have the same spindles? I want to be positive before buying
TexasRammer
College Station, TX
No problem. and I can speak from experience that springs and spacers will kill your ball joints, so does off roading... lol. little spacers arent that bad, highest I would go is 1.5", but if you do more you need cross member drops which usually only come with lift kits
bloombloom88
bloombloom88
Plano, Texas
So lets say, the 7 inch cst lift, which uses a 4 inch spindle and 3 inch springs, still creates that stress due to the taller springs?
