Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have a 2023 limited crew cab 1500 that has the 3.0 eco will need to change the fuel filter soon. What filter have you been using? Any brands to stay away from? Any Links to replacement procedure?
The DT body truck use a different style filter.
The general consensus amount a lot of EcoDiesel owners is to run the OEM filter. With there only being one fuel filter on the Ecod and components it protects are not cheap to replace, it's not a filter you want to go cheap with.
Don't buy filters from Amazon, have seen a lot of post pertaining to fake and/or cheap knock off OEM filters (and other various parts).
OEM Mopar only, end of story. Geno's garage is the best place to get them. There is a high risk of knock-offs so make sure you get them froma dealer or Geno's.
The only non OEM fuel filter I would trust is the Baldwin PF46152, some times if ya take the time you can find the Fleetguard FS20378 cheaper than Mopar FS_68436631AA-1 that is just a re-boxed Fleetguard filter. BTW Doc Diesel China filters do not meet OEM specs so if your still under warranty I would suggests that you don't use them
