3/4 loses almost 1k payload for diesel 1ton loses nothing?
cc rider
Western NY
So, I was looking at a build sheet (this is for 2014's). The 2500 w/ 6.4 has a 3180 payload and the diesel has 2230 payload. Now on the 1 ton the 6.4 has a 4060 payload and the diesel has a 4020 payload. Why does the 1 ton only lose 40 pounds? Or is this an error? This is regarding a big horn crew cab 4x4
loveracing1988
Clarkston, MI
The GVWR on the 2500's is 10000 pounds for both the 6.4 and the 6.7. On the 3500's though it changes depending on engine size, the 6.7 gets another 1000 pounds of GVWR hence the loss of only 40 pounds of payload.
C
cc rider
Western NY
Interesting. So if u play with heavy toy haulers, and want a diesel get a 1 ton , not a 3/4 since the payload isnt that great on the 3/4 6.7.....or get a 3/4 gasser
NYCruiser
Yonkers, NY
Agree. 2500 doesn't have the headroom left in its GVWR to get the full rating its capable of.
shaftman_05
Southern Michigan
There is more to payload than engine size.
Frame capabilities
Brake capabilities
Suspension capabilities
Etc.
Not to mention they add the DEF tank and added weight of the engine which is what takes away from it.
loveracing1988
Clarkston, MI
Frame capabilities
Brake capabilities
Etc.
Same exact frame
Same exact brakes
The difference is the rear suspension which keeps the leaf springs which provide good load support but not the best ride quality.
14hemiexpress
6.4l
Same exact frame
Same exact brakes
Will the 1 ton with the higher gvw have different front springs? Because that would help take the load of diesel and keep good payload.
loveracing1988
Clarkston, MI
Any diesel will have a higher rate front spring to help support the Cummins. That is for both the 2500 and 3500.
xrsman
Ontario
3.0 Ecodiesel
Same exact frame
Same exact brakes
Yep ^ on the old f-350's if you bought a 350 and didn't like the ride, take out a leaf and you now have a 250 lol.
CabinDweller
Cummins 6.7L
The 2500 payload limitations are exactly why I ended up with a 3500. Most 5th wheel campers (pin weight) that we'd likely upgrade to in the future put us over the 2500 payload max. I was really surprised.
