3.75 dodge combo lift
Shipman
I was thinking off putting this lift on my dodge crew cab and was wondering if anyone else has done this to. I am thinking of putting 35s on the truck once I get the combo lift done. So what are yalls thougt about the lift and what tire size do you recommend? I am new to this forum so sorry if there is already Somthing about this!
chipmaker
AZ
If u just want to get 35s on, do what many including myself have done. Bilstein 5100s set at 2.1 or 2.8.
N1ck
Regina Sk
I really do like that 3.75 combo, makes the truck really stand out and is reasonably priced.
S
Shipman
What do you do to the back of the truck if you get the 5100?
N1ck
Regina Sk
You can leave it stock are get a spacer lift which goes under the rear coil springs. They're $75-$100 usually. I ran a Motofab 2" rear before my 6" RCX.
DisturbedGator
my sig is my 14 on 35x13 with bilsteins at 2.1 everything else stock
S
Shipman
Thanks for the help guys!
brasso
2012 ram 1500 4x4
Why would you want a year spacer?? It just adds even more rake and looks even more ridiculous with the rear end way up higher than the front
jstacey8
hiram maine
the bilstiens at 2.8 make the front of the truck higher so some people want there to be rake because they tow or just like the looks of rake or add a small spacer to the rear so it is level its different from person to person
jlb
MT
CTD
Calm down, no need to get all opinionated. Some of us use our trucks, and the rake is advantageous as the truck sits around level when towing, or hauling heavy loads.
