3 inch rough country bolt on lift
jtruelove
Houston tx
6.7 diesel
trying to figure out if i can fit 35x12.50r20 tires on my 2017 ram 1500 4x4 with a 3 inch bolt on rough country lift. on stock rims
BTD07
2017 Laramie
You can fit 35s on a level, so yes
jtruelove
jtruelove
Houston tx
6.7 diesel
the 3 inch lift should be a inch higher than the level
Ratket
Arizona-
I think it will rub due to the offset of the factory 20”s I have their 3 uca kit and there is not much room between the tire and the uca now. I would recommend a spacer or more offset wheel.
jtruelove
jtruelove
Houston tx
6.7 diesel
i ended up running 2 inch spacers. no rubbing at full turn with 35/12.50r20 on factory rims
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Depends on the back spacing. Some OEM rims are 20x9 others are 20X8 with different offsets.
