360 Plugs
Fast69Mopar
Whats everyone running for plugs in your 360?
I like to use the Autolite 5224's in a stock motor or the Champion 436's. Make sure you use only a copper core spark plug. These motors do not like a platinum plug no matter what the parts guys try to sell you. If you have some performance work done to the motor and are experiencing any spark knock then I would suggest switching to a slightly colder heat range plug.
In my race motors or ones that I build for some hot street applications I use the Brisk spark plugs. A Brisk spark plug that is comparable for your 360ci Mopar would be the LR17YS-9.
SportRam00
Joppa, MD
Magnum 360
I use recommended OEM stock Champion RC12LC4 copper plugs. They seem to work fine. A lot of guys recommend the Autolites mentioned by Fast69Mopar and experience better idle and throttle response from them. I haven't tested them personally.
Fast69Mopar
Just a bit of info, the Champion RC12LC4 is the Mopar part number and is the same as the Champion 436.
Mop
I've been running NGK Copper Core for many years.
