37s sure look good.
AustinB
Banned
San Diego, Left Coast
Yep, they'd look purty good stuffed up in there!
Too bad I have these 3:21 highway gears that can hardly run anything over 33x11. Guessing I'd go from 13mpg to around 10mpg.....nope
Going to put this truck on the market at the beginning of the year and go with a sfa hd model. Probably 2500, definitely diesel. I get somewhere around 8mpg towing and it hurts the wallet..
Trying to decide on a good gen.. early 3rd gens are my favorite body style.. but I don't know much about the Cummins, yet (give me a week or two to read up)
Any recommendations of what years to want/avoid? Buddy of mine mentioned 2011 ish (cant remember, dont care to look it up atm) had a big jump in torque and pre def. Im just not thrilled about these 4th gens. I like cheap replacement stuff, a lot of build/tech info to be readily available, great aftermarket support, and reliability.
zeddy
Burbank, Ca
Plasma cutter will get those tires fitted in no time.
Ratket
Arizona-
You get the 4th gen body-
6 speed tranny
Pre def-
As to be my optimal year if I was gonna buy a diesel.
zeddy
Burbank, Ca
They will fit w/o any trimming. I think you just looked at the picture and didn't read a single sentence .
They are 6 lug wheels.
That's exactly what I did.....hahahaha:roflsquared:
I agree with Ratket, 4th Gen. Pre def....can't go wrong.
kg93
AZ
you daily your ram dont you? I would go with the newer 10-12 pre def 2500. Gets you a newer interior and less problems. Not so much the cummins itself in the 3rd gen but the rest of the truck
Ronan
From what I've read the 06's are a beast and easier to modify. I'm no expert though. I'm sure you'll find some good info with a quick search. I do like the third gens as well. Good luck!
DannyMK2
Long Island, NY
2015 Power Wagon
3rd gen cummins 5.9 is a tank. i love mine. only complaint is the interior is no where near as nice/comfortable as the 4th gen, imo.
Rzrman328
The treeline
I'd be happy with an older 2500. Also up in the air about gas or diesel.
Don't really need a diesel.
Csanders1992
If I were to buy a 3rd gen cummins, it would be a 06-07 5.9. In 07.5 they switched to the 6.7. But like others have stated I'd get a 4th gen. Don't get to caught up on the pre-def if you plan to delete emissions anyway.
VB712
Maxi_built
Va Beach
I had a 2012 2500 cummins. Awesome truck. Only real issue I had in 3 years were ball joints. I had a ton of aftermarket things on it as well.
6.7CumminsDrvr
The Dude abides………
Georgia
Go 4th gen........I had an '08 and '10, the interior is a HUGE improvement. And the 68rfe ain't bad if you know it's weakness. 5.9's are gems IF you can find one but good luck there ��
I deleted my '10 and it was a beast, sure do miss that truck IIRC, the '10 and up could be deleted and the EGR could be left alone under the hood as the electronics could disable it.
Gump
Butte, MT
Best Cummins trucks are 95-98. Comfort would be 4th gens. Compromise on both would be 06-07. I've owned every generation, and this is my personal opinion.
AustinB
AustinB
Banned
06ish would be more in my ideal price range for a tow rig. I can swing a 4th gen if I throw back a few shots first
Ideal mileage I should shoot for/stay under?
Some more reading I guess I should do is something about a number/letter on the engine block I should avoid...?
Csanders1992
06ish would be more in my ideal price range for a tow rig. I can swing a 4th gen if I throw back a few shots first [emoji482]
If your looking at 07s make sure to look at the vin number. That'll quickly tell you if it's a 6.7 or 5.9 without even seeing the truck
blackbeautyhemi
Lewistown, PA
Make sure it's a southern 3rd gen cause these damn bedsides rot out from the inside. Knock on wood I've been lucky with mine so far.
Gump
Butte, MT
06s are pretty solid. Some people have to replace injectors, but mine have been fine. I look for under 150K if it's an auto. I'd say you can go 250K without major maintenance.
noraa73
