3rd Gen cab lights on 2nd Gen truck?
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
Hey guys, are the late (98/99-02) 2nd gen cab lights the same as the 3rd gen cab lights? im about an arm hair away from installing 3rd gen LED cab lights on my truck but i want to first make sure they ill work on it. if anyone knows please let me know.
CumminsCrazed
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
ok, one guy said the "bolt pattern" is different on them, but if i don't have cab lights at all now, that shouldn't matter as there's no holes now from previous lights to worry about correct?
AWE Daniel
Banned
Yup that's what I mean, he'll they could be made for another brand of truck as long as they fit the roofline the rest is up to you
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Daniel is right on. If you don't have cab lights now then you have to fit them on the roof and wire them up. Make sure you seal them good. The 3rd gen lights are a different style of coarse. But the wirine may have changed. But you're making your own wiring so it won't matter.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Yea as long as you don't have lights now. Wire them up yourself. And you're good to go.
ramhunter9
P-Star Jeep Wrangler
pull your passenger side pillar , the wire harness end is in there . Those are the wires for your cab lights . Most rams have this in there from the factory with or without light .
So all you have to do is run wires from the lights to the pillar .
AWE Daniel
Banned
interesting..... are you sure thats true for 1500s, seems like it would be for 2500s +
ramhunter9
my 04 1500 had it also .. go look just 2 screws
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Ditto max. RTV and maybe some silicone. George did an install writeup well video on his you tube.
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
my 2500 - 1000 has the pillar tapped
got the wiring harness from a chevy 3500 workman special out of the pick and pull for free since it was closing and was only 5 feet of wire
lilfroger
5.9 CTD
Zach the other thing to remember...the 2nd gens have an existing template w/ cut outs for the cab lights under the head liner.
You very well might find yourself fighting the sheet metal.
Best of luck!
CumminsCrazed
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
Seeing as how other 2nd gens have 3rd gen lights I don't forsee fighting the sheet metal to be much of a problem. Hell I'm only drilling holes in the roof anyway. I will ask my buddy about harness etc for cab lights and see if he knows about it.
OasisNinjaBat
