4” superlift question
Reese324
PA
He I 5.7
I’m about to pull the trigger on the 4” superlift w/o the bilsteins. I currently have the bilstiens in the front at 2.1, 305/55/20 on 20” fuel vandals +1 offset. I’ve only had the tires for less than a year so getting the 35’s right now ain’t happening. Question I have is will the truck look bad w only the 305’s? I looked on custom offsets. But didn’t see any of my setup. Other question is I should be able to keep my bilstiens in the front and adjust them down to kee the truck as level as possible. Any and all I do is appreciated
Ohio5pt7
Ohio
Imho anything smaller than a 35 look small on less than a 12 wide. I have seen 33s on 12 wides on a 4" that looked pretty good but I've seen some that looked bad. That's why I opted to go 6" and 14 wide lol
Sent from my KYOCERA-E6920 using Tapatalk
Dub1
BC
5.7L
It'll look good but you'll probably want 35's eventually. That 4" superlift is going to max out your CV angles so use at your own risk offroad.
Ohio5pt7
Ohio
The 4" comes with the same diff relocation bracket as the 6" I have the 6" superlift with bils and my angles are fine
SOKY_RAM
Bowling Green, KY
Should be exactly the same as just having bilsteins at 2.1
Nick@GotExhaust
Supporting Vendor
SC
I think it will look ok, as mentioned you still will want a larger side wall eventually.
Let us know if we can help, we offer Superlift. Message me if you would like a quote.
6.7CumminsDrvr
The Dude abides………
Georgia
I initially ran 285/65/20 when I had my 4” Superlift installed (Dropped my Bils from 2.1” to 0.7”), didn’t look bad IMO but those spec out to 34.5” so they were essentially a skinny 35.
