4.10 w/LSD vs. 3.55 Open Dif - Gear Swap Review
DavidRam
SoCal - Redondo Beach
2012 RCSB
If anyone is considering having this done, maybe this will help (not on tech issues, but more on the feel and performance). :)
Had 3.55 open dif, swapped for oem 4.10 w/oem LSD. Used Royal Purple gear oil (it's premixed with lsd additive), mini install kit, all new bearings, Mag-Hytec dif cover (I had a little issue with it fitting).
Immediately I noticed the following:
1. Smoother yet, more sensitive throttle reponse
2. Smoother shifts, less shifting and searching for gears
3. A more balanced and planted feel on acceleration
4. More engine braking, which I like (something I miss about a stick shift)
5. An overall lighter more agile feel to the truck, less bogging down
Now, if I could only speed up the 500 mile break in period!!!
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
The Spohn is the same OD as stock. Glad you said something, I was looking at down that same mod!
ladiesman217
Having my truck with the 4.56s in it for a little more than a week.
I noticed the same thing with the engine breaking scenario.
I find my self often trying to coast up to a red light and I have to actually hit the gas for a second or I would be holding up traffic haha.
Statcher1
Kentucky
What was the cost of the gears and everything to so the swap. Minus labor. If you don't mind me asking
DavidRam
DavidRam
2012 RCSB
Not cheap, I'd have to check my receipts to be sure, but roughly $1,200 just for oem 4.10 gears and oem lsd (same parts as the R/T). Motive makes cheaper gears, though, see Moes.
Here are approximates:
Gears and LSD = $1,200
Diff Cover = $250
Install Kit = $30
Bearings = $150
Royal Purple Gear Oil = $60
Total = $1,690 (those are off the top of my head)
DavidRam
DavidRam
2012 RCSB
Yep, I love it! I was born and raised in Germany, so growing up and getting my license, EVERY car was manual, automatic was very rare.
Me and my friends would race our Golf GTIs around - down shift and engine break to nearly a dead stop, barely touching the breaks for the last couple feet!
DavidRam
DavidRam
2012 RCSB
I am not saying that it won't fit. Maybe I have the odd truck... I would definitely measure first. Before you either order it or write it off.
I think you have the same kit that I am getting from Moes and maybe if we are lucky the cover will fit after the drop...
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
I am after that diff cover. My buddy has a Laramie like mine and I think the rear sway bar either gently touches or has an inch to spare from the cover.
It looks great though and I can't wait to get one.
DavidRam
DavidRam
2012 RCSB
An inch to spare would have been awesome, mine would have gently touched it, had I put it in.
MR.REMBERT
Santa Barbara County, CA
How do you know if you have LSD? My build sheet say "3.55 rear axle ratio" it also says "Electronic Stability Control". Is that the same as LSD?
fasthemiram12
Eagle 5.7 vvt
did your GF drop come with a relocation bracket? iirc they don't and that's possibly why it isn't working.
My Belltech 4" came with one and it drops the bar lower
DavidRam
DavidRam
2012 RCSB
I don't think it did. That is a great point.
But my greatest concern is not it not fitting now, but rather will it fit with a 2/4 Belltech drop kit... I think it could because I am doing the upper and lower control arms, but not sure.
Does anyone with a 2012 RCSB 2x2, have a 2/4 drop and the Meg-Hytec diff cover???
DavidRam
DavidRam
2012 RCSB
Technically, I could "make" it fit with the adjustable control arms... right?
Darkflow
Odessa, TX
Check to see if your wheels are centered right now. When you lower it, the rear tends to shift forward. The lower control arms just re-center it but if you are centered now and may touch. You still may touch with the lower control arms. My guess would be the rear isn't centered dead on right now though. Most aren't from the factory.
DavidRam
DavidRam
2012 RCSB
FYI, the Mag cover is 3 3/8" high (or thick or deep or whatever you call it).
I am wondering if the Mag-Hytec will fit after I put in the Belltech 2/4. :superhack:
fasthemiram12
Eagle 5.7 vvt
All you need is a relocation bracket
DavidRam
DavidRam
2012 RCSB
Cool. I am keeping the Mag-Hytec diff cover and making it work.
1. When my truck was on the rack is when it wouldn't fit without touching the bar. But I did not try it when it was on the ground.
2. Or I will grind a little groove into the fins to make it work.
Either way, it IS going on the truck! :)
TMFMK
